DesignSeries02350.pngDrawing walls
Tool
Workspace: Tool set
Shortcut
Wall
Round Wall
Architect and Spotlight: Building Shell
Landmark: Building Shell and Site Planning
9 (Wall)
Alt+9 (Round Wall, Windows)
Option+9 (Round Wall, Mac)
The Wall tool and Round Wall tool create hybrid wall objects, simultaneously adding both a 2D and a 3D version of the wall to the drawing. Although they are drawn with different tools to create the varied geometry, straight walls and round walls create the same kind of wall object and can be joined in the same wall network. Walls can be drawn in Top/Plan or in a 3D view. Standard walls and curtain walls are created using the same tools.
Create walls by drawing them with the mouse, or by using a mouse-Data bar combination (see Using the Data bar). The following directions assume that the walls are drawn with the mouse.
If walls are drawn using the Data bar, the Control Line mode setting determines whether the dimensions entered are for the left, center, or right edge of the wall, or a custom location.
To create walls:
Click the tool, and then click the control line modes and the creation mode (see Creating walls).
Do one of the following:
Click Wall Style from the Tool bar to select a resource from the Resource Selector; see Using wall styles.
Curtain wall styles in the Vectorworks libraries begin with the prefix CW for easy identification.
Click Preferences to open the Wall Preferences dialog box and specify the tool’s default parameters. Depending on the Wall Type, see Standard wall preferences or Curtain wall preferences.
The parameters can be edited later from the Object Info palette.
To draw a straight wall using Polygon mode, click at the starting point of the first wall section, and click again at the end of each wall section. Double-click to finish the wall if the start point and end point are not at the same location; otherwise, click at the starting location (a SmartCursor cue displays) to finish the wall.
Alternatively, after completing all but the final click, press the keyboard shortcut (K by default) to automatically close the polygonal wall network. See Modifying special shortcuts to change the shortcut.
When drawing a wall network, move the cursor in the direction of the next-to-last click but press the shortcut key (K by default) instead of clicking; the software extrapolates the correct alignment and position for a 90° corner and places the final two clicks to complete the wall network.
To draw a straight wall using Rectangle mode, click at the wall’s start point; this becomes one corner of the rectangular wall system. Move the cursor to the opposite corner until the desired size is previewed, and click to set a corner point on the wall system. Four walls are created.
When the Vectorworks preference Auto-join walls is on, walls drawn in Rectangle mode that overlap or touch each other interact, so complex wall systems can be drawn quickly. See Automatically joining walls in Rectangle mode for the rules that define these interactions.
To draw a round wall, click to begin drawing the wall, and click again to end the wall as required for the selected creation mode (see Creating arcs).
Creating walls
Wall direction
Using wall styles
Editing walls
